Hi all,
Long time lurker, first time poster
I need some help regarding case choice. First of all, some specs
Abit AB9 Pro mobo
intel e6700 core2duo
4x1gig ddr800 corsair (paired)
sound blaster x-fi fatal1ty
XFX 8800gtx
3.5" floppy + card reader
Pioneer 111D dvd-r
Plextor 750a dvd-r
Raptor 37gb
2xRaptor 74gb (RAID 0)
WD Caviar 500gb
antec trupower 500
Sound card + mobo both have a 5.25" slot thingie that I would like to keep
I use the small 37g raptor as c:\, and that only has windows + some program files on it, the raid is for game installations only.
Since getting vista, the 37g is struggling for space, so I want to upgrade it. I recently got a 150gig Raptor X, and I was going to get the Armor Jr for it, seeing that it can display the clear side of the Raptor X
But, the more I read about the matter, I think that if you install the raptor sideways (ie with clear side showing through window), you actually block the use of the 4 3.5" bays! That sucks cos I need them for the other drives.
What I'm looking for ideally is a case that can:
1\ Display the Raptor X's interior
2\ has 4 external 5.25" bays (2 dvd drives, s blaster, mobo)
3\ has at least 3 internal 3.5" bays (other than the raptor x) for the other drives.
4\ has one external 3.5" bay for the floppy (yes, I want to keep it
I initially thought I would get the Jr, ditch the mobo's front panel, and install the 2 dvds, the s/blaster's panel, mount 2 hard drives in 5.25 bays, and one in the power/reset 3.5" bay. The raptor x will go in the sideways 5.25 slot. Not sure I can keep the floppy like this?
Any advice highly appreciated and many thanks for reading, and for any replies
PS: to mount the Raptor X sideways, the thermaltake website says I need an adaptor (a2407) which I cannot find anywhere at all. I'm guessing that all I need to do is get a 3.5 to 5.25 bracket? seeing that the armor's sideway 5.25 bay is standard? Please, again, any help or explanation with regards to this is greatly appreciated.
Ta
Abit AB9 Pro mobo
XFX 8800gtx
Pioneer 111D dvd-r
Plextor 750a dvd-r
Raptor 37gb
WD Caviar 500gb
antec trupower 500
)I initially thought I would get the Jr, ditch the mobo's front panel, and install the 2 dvds, the s/blaster's panel, mount 2 hard drives in 5.25 bays, and one in the power/reset 3.5" bay. The raptor x will go in the sideways 5.25 slot. Not sure I can keep the floppy like this?
Ta
