Hi all, just wondering if these cases would be ok for the following system.
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775)
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit
Connect3D ATI Radeon X1950 Pro 256MB GDDR3 HDTV/Dual DVI
Western Digital Caviar RE 160GB 1600YS SATA-II 16MB Cache - OEM
NEC AD7170A 18x18 DVD±RW Dual Layer ReWriter (Black) - OEM
I am on a budget so its been tough to try and decide on a case, as buying a case and seperate psu seems expensive, so basically I am just looking for a decent case and psu to last a few months and that will do the job.
The cases I have been thinking about so far are.
Antec NSK6500 Super Midi Tower Case - 430W PSU
Antec Sonata II Piano Black Quiet Case - 450W Smart Power PSU
Akasa AK-ZEN-01-BK Zen Black Case - No PSU
Akasa Ultra Quiet 400W Paxpower Active PFC ATX2.2 PSU - Black Nickel
I really like the look of the NSK6500, plus seems an decent enough PSU.
Same goes for the Sonata II and I heard good things about this case also.
The Zen has great reviews and does seem great for the price, but I don't like how it looks. But its not about how it looks its about how good it is at cooling and ofcourse the noise factor.
All of the above are in my price range, but I'd like some opinions and maybe better suggestions if possible?
Thanks for any help.
