A colleague wants to know which case people think is better out of:
CoolerMaster HAF 922
CoolerMaster 690 II Basic (Is it worth the extra for the 'Advanced' version?)
Initial plan will be to set it up for water-cooling, does this affect his choice? May be used later for non-water-cooling.
Plan to use a to mounted 120x240mm radiator, which one does this best?
Will they both fit a 4870x2 graphics card?
Any other cases in this price range that would be better?
