Hey all im going to get a new case soon as my current case doesnt have much room to fit a pa120.2 without removing the graphics cooling cage thingy on my tj09 (or any other sujestions? its too fat to fit at the top once the fans are added) and mounting it verticaly some way there.
So i was thinking about either a lian li G70 or a V2000+, basically a want a case with a lot of room to house whats in my sig plus these watercooling parts, Thermochill pa120.2, DangerDen DDC+ with plexi top, DangerDen Bay res.
What case would be the least amount of effort/least amount of modding to install a pa120.2 inside? or anyone have any sujestions on installing this rad into a tj09? I was going to just remove the graphics cage (easy enough to remove already took it off to change the fan) install it verticaly next tro the mobo and get myself a DangerDen 8800 GTX waterblock for my GTX (which i plan on anyway) as soon as i can bloody find one in the UK, but im not sure how hard this will be and if there will be enough airflow etc without cutting the case which is why i think ill just get a case more suited to housing watercooling parts, the tj09 is a great case n all but only for air cooling.
Any help much appreciated![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
