which case
20 Jul 2006
Iam after a case for a conroe system but i might add water cooling at a later date so i need something with space.
Also what PSU should i go for :confused:
Thanks
I wouldn't get a p180 if you intend to get water cooling, as it could be tricky to mount a rad internally due to the tripple layer panels. The Asaka Eclipse 62 would be a good choice, as would something like the Lian Li G70 or v2000.
