Which case?
30 May 2004
Northamptonshire
Okay i have a gaming bomb; i want a new case and am looking at the following:
- Chembro Gaming Bomb 2
- Lian-Li V1000
- Silentmaxx ST-11 PRO
All of the above I'm looking to get in black, want it to be quiet and will need to accommodate system in sig.
Any other suggestions welcome :D
EDIT: PSU is Modular
Thanks in advance
Out of the ones you have looked at, the v1000+ is way better than the others. So if you like the look of it, I would say go for it. Can't go much wrong with a lian li v1000+ really. :)
cheers for the quick response; I'm a bit worried about the PSU being modular and fitting it in. My friend has a Antec P180 and had trouble with a modular PSU fitting...so will i be okay?
I have a modular PSU (tagan 580W) and V1000+. It fits fine with the extra drive rails removed. Anyway, who needs 6 hard drives?
p.s. great case. i've been very pleased with it.
