Chaps
I'm after a case for a new PC...use will be primarily gaming, not being dragged around to LAN parties though.
Its going to be a e6850 / 8800 GTX PC which will run at stock initially but may well see a bit of overclocking. I'm not too fussed about size or appearance. Doesn't need to be massive as I'm not planning anything exotic Hard disk wise.
I like the look of Lian-Li PC V1000 PLUS Aluminium Midi-Tower but would happily spend a bit more or less depending on the strength of recommendation.
I think I've read somewhere that these don't have a reset button...does that matter?
I'm not a silence fanatic but ideally cool and quiet-ish would be nice.
I'd appreciate any views.
BTW will be air cooling!
Cheers
Cheers
) then get the antec900..
