Which case?
3 May 2004
Im having a hard time decideing what case would be best for my needs.
The system im building next month will mostly be used for gaming and general internet use, processor will definatly be a Q6600, hopefully the energy efficient one.
Anyway, Im currently looking at the SG03, SG01 & Q-pack.
Which as general better air cooling?
Also, are these cases any good for water cooling, as I may consider and external system later on.
Thanks all.
sg03 and sg01e have both been mod'd to do internal watercooling :)
I would pick the sg01e as I have one but the sg03 supposedly has better cooling.
Reppyboyo said:
I'd like one also please.
Generally, the SG03 is the better cooler due to a pair of 120mm fans. The SG01 has to make do with two 80mm ones above the graphics card, one on the HDD bays, and the PSU fan.
found them at ******* forum iirc been a while since I've seen them.
this thread should basically show you what can be done with an sg01e and some extreme modding.
why the hell can't you link to that forum, its not like its a competitor !!
Ty got it now.
Awww ive seen this, its off hardforum forum its called loasis or something like that.
