Not sure if it fits your modding requirements, but I have a Silverstone Fortress FT-01 and couldn't be happier with it. Looks great, ace built quality, understated and good thermals.
Within your price range too![]()
what is the difference between these 2 caeses?
http://overclockers.co.uk/showproduct.php?prodid=CA-110-AN
http://www.overclockers.co.uk/showproduct.php?prodid=CA-102-AN&groupid=701&catid=7&subcat=160
It has a side cooling grill which supports a 200mm fan (not included), though in reality i'm sure you could find a way to attach any fan up to 200mm pretty easily.does this have a side window or not?
http://www.overclockers.co.uk/showproduct.php?prodid=CA-176-CM&groupid=701&catid=7&subcat=29
I am going to get this case:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-156-CM&groupid=701&catid=7&subcat=
where can I can get the transparent side panel for it?
Ah so you like hideously ugly casesI have had a look and it is £130
I have had a look and fancy these which one would you reccomend:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-110-AN&groupid=701&catid=7&subcat=160
http://www.overclockers.co.uk/showproduct.php?prodid=CA-042-CT&groupid=701&catid=7&subcat=1408
What do you guys think?
