Which case?
4 Mar 2011
Hey guys.
I'm having a hard time choosing between a couple of cases.
The Coolermaster HAF 922, and the Antec 902.
Could you guys help me decide and tell me your experiences with both?
Thanks.
-DreadAlert-
922.
While both are excellent at cooling and will take all gfx cards the 902 is so damned noisy.
I also prefer the aesthetics, interior and cable management (because it actually exists :p) of the 922
690II is an awesome case. My second option was the HAF 922 though - turned out the 960 II had more features, but propbably not as cool (still cool though will all the fans.)
H922 by far, though you may want to create a couple of air filters for the bottom and side air grills since they are inlets and if the case has any faults at all then it is the lack of air filtering on the underside and side grills
The HAF X does supercede the HAF 922 in many ways, However, The HAF 922 is approximately £50 cheaper than the HAF X.
As for the home made air filters for the underside and the side air grills it cost me £2 for materials and it's enough materials to do the job 5-8 times.
I haven't looked at the antec cases so i can't comment on those.
