I have been looking for a case for a new build (my first!) and have spent weeks trying to decide but with no luck. Thats why I am now asking for a little help.
I would ideally like a full tower case because I would like plenty of room with a USB 3.0 front panel (Not bought motherboard yet so could always buy one with USB 3.0 tray if neccessary) and side window panel. I will be air cooling so would also like a case that is good for this. On the case size one query I have is there really that much difference between the size of some mid tower cases compared to the full tower ones as loooking at the dimensions there sometimes doesnt seem to be?
I am torn in 2 regards price. I would like to spend around £100 but I could be persuaded to spend up to around £150 if the case fits the bill and looks the part. I have seen some cracking cases for around the £200 mark but find it hard to justify spending this much on a case but again I could be persuaded....
These are some of the cases that have some or all of the features that I am looking for:
Budget options
Cooler Master CM-690 II Lite Dominator Case - Black [RC-692-KKN3] - £59.99
http://www.overclockers.co.uk/showproduct.php?prodid=CA-212-CM
Fractal Design Define XL Full Tower Case - Black Pearl - £84.98
http://www.overclockers.co.uk/showproduct.php?prodid=CA-011-FD&groupid=701&catid=7&subcat=1556
Mid range
Lian Li PC-7FNWX Aluminium Mid Tower Case - Black - £132.98
http://www.overclockers.co.uk/showproduct.php?prodid=CA-193-LL&groupid=701&catid=7&subcat=187
Antec 1200 Twelve Hundred (V3 with USB3.0) Ultimate Gaming Case - Black - £139.99
http://www.overclockers.co.uk/showproduct.php?prodid=CA-165-AN&groupid=701&catid=7&subcat=160
Cooler Master HAF X Gaming Tower Case - Black (RC-942) [RC-942-KKN1] - £129.98
http://www.overclockers.co.uk/showproduct.php?prodid=CA-203-CM&groupid=701&catid=7&subcat=29
Persuade me range
Lian Li PC-A70FB Alumiinium Full Tower Case - Black - £173.60
http://www.overclockers.co.uk/showproduct.php?prodid=CA-171-LL&groupid=701&catid=7&subcat=187
Corsair Obsidian 700D Full Tower Case - Black [CC700D] - £158.99
http://www.overclockers.co.uk/showproduct.php?prodid=CA-025-CS&groupid=701&catid=7&subcat=1489
I can dream
Silverstone Fortress FT02B-W Windowed Gaming Case - Black [SST-FT02B-W] - £219.98
http://www.overclockers.co.uk/showproduct.php?prodid=CA-067-SV&groupid=701&catid=7&subcat=1092
Corsair Obsidian 800D Full Tower Case - Black [CC800DW] - £224.99
http://www.overclockers.co.uk/showproduct.php?prodid=CA-020-CS&groupid=701&catid=7&subcat=1489
As you can see i like cases with a more classic look and nothing too strange/ugly. My view is that if money was no object that I would buy the Corsair Obsidian 800D as it seems to be far and away the best case and looks the best imo but I just cannot justify spending so much on a case. The same applies to the Silverstone Fortress FT02B-W. In the cheaper options the Cooler Master CM-690 may be too small and too old now and the Fractal Design Define XL seems a little dull. I have never seen these in the flesh so could be wrong and am open to being told otherwise. The rest all seem to have pros and cons. Are there any other cases that I havent noticed and what are your views?
Budget options
Mid range
Persuade me range
I can dream
