Which Case?
27 Oct 2020
Morning all, just checking for some advice.
I have ordered a Phanteks P500 DRGB. However it looks like the shipments havent been recieved by OC as scheduled.
I have been eagerly gathering all the parts needed for a new build for the Ryzen chips released today.
So now I am stuck with a quandary. Being impatient I want to start putting this together as soon as I can.
Do I wait for the P500 to come in, which I am not not confident will arrive promptly now.
Or do I change my order to a case in stock.
For instance I am considering changing to the P600s. But what other cases should I consider for an ATX board, and with a plan to roof mount an AIO cooler.
Check out the new Corsair 4000D (or icue 4000X if RGB is your thing). Excellent feature set, for under £80 (£110 for the extra RGB fans - which isn't obscene)
Allatar1. I’m in EXACTLY the same situation as you and have been looking at alternative cases, which in turn messes with my 360 AIO/taller RAM choices. Not sure which colour you wanted - I have a white case ordered.
Spoke to OC today, they confirmed stock of the white P500a arrived to warehouse yesterday. 100 units/72 pending orders and would be shipped early next week. Might be worth calling them if you don’t already have the white on order and would settle with it.
Thanks Both. I wasnt confident on being in the batch for the P500 as I ordered at the end of October. After looking I decided to go for the P600s instead.
