Which cases should I consider?
26 Feb 2012
My current case is crammed and hot and needs to go asap.
My specs are:
Asus P8Z68-V/GEN3
I5 2500K
Coolermaster hyper 212 evo cooler
8GB Corsair Vengeance RAM
MSI 7950
Corsair force 3 120gb SSD (With OS)
Seagate 500g HDD
Corsair VX550W
I plan on getting another SSD with the case and eventually another 7950 will be purchased for crossfire.
My main needs are:
1) Cable Management
2) Great cooling
3) Built in SSD compartments
What are the recommendations? Budget wise I would rather not spend more than £75 but will stretch a bit further if the case is really that beneficial.
Fractal Design Arc Midi
Fractal Design Define R3 or R4
Nanoxia deep silence
Bitfenix shinobi
Coolermaster silencio 550
This would be my list on £75 budget or less
Don't like how they wont give a date they said sometime in march, then they changed to sometime in April...
You can already get them in the USA....
But anyway, wait for the midi R2.
The fractal design cases look really good although I was hoping for a bit more video card leeway than the R4 case has. It is definitely a front runner. I saw an antec one I liked the look of the other day as well.
I like the look of the corsair 300r case but they seem to lack the space for my cooler.
