Which centre speaker
14 Oct 2007
newcastle
I’m looking for a centre speaker for my new setup the problem is the centre can’t be more than 8-10cm high can anyone point me in the right direction, I’m looking at the £300 mark
If it's 8cm, then I would say forget it. That's just too small. Get a soundbar or sound base.
At 10cm, you might just scrape in with a Gallo Micro SE sound sphere which is 10.1cm tall. However, you'll need a sub that can go up to 120-130hz in order to do a clean crossover with the Gallo. Small cabinet size means small speaker drivers mean high crossover points.
