Which chipset cooler? Asrock
Permabanned
28 Feb 2006
Which chipset cooler? Asrock - Pic
Hi, got the asrock 939 dual, as it is a budget mobo, there has to be faults..
Well, its RED hot (Did you like that :p )
So, I need a "Northbridge cooler" (Thats the thing which is really tall right)
And a chipset cooler (Which is the orange/gold thing on the mobo)
Heres a pic of what I need and the things which are hot. (In yellow circles)
What should I get? Only got £15 for both inc vat, excluding postage.Which is enough I think.
Akasa AK-210 Blue LED Chipset Cooler (HS-026-AK) - £3.15 is that what I need where do I assemble it where the grey one is or the orange..
Sorry if its a bit complicated ( Im hot) :o
You not got an old fan that you could mount so that it is blowing cool air over them?? Saves replacing the ones that are on and when the weather cools off a bit then it'll run cooler anyways. Just idea to save some cash and the hassle of changing the coolers.
odd, it shoudl not be getting that hot, mine runs just warmish.
get the nb-1 from thermalright, im using one on my msi board with fan running at 5v its silent yet provides top notch cooling.
