I have been buying bits and pieces to convert one of my existing bikes of which the gears are knackered into a single speed bike, but it is giving me headaches, so I have decided to just buy something new. Daily commute, about three miles each way on flat tarmac, so nothing fancy required.
I have been primarily looking at the Vitus Vee, which at £224.99 looks good value, though I am a little put off by the fact that it looks like a jack of all trades, rather than a tarmac commuter.
These are the other bikes I have seen within the £300.00 budget I have -
Charge Plug @ £299.99
Claud Butler El Camino @ £247.49
Norco Cityglide @ £280.00
Jamis Beatnik @ £265.00
I am assuming that component wise there is not much between any of them but is there one which stands out, or have I indeed missed another bike for my requirements?
Cheers
Cheers
