which cleaner
25 Jun 2009
which cleaner is best for bare aluminium (Lian Li), i've tried Acetone industrial and White spirits, but both leave behind smears when they dry, it's on the inside panels..... thanks
I've heard white vinegar can be used to clean aluminum, a lot of classic car people use that. Personally I'd check on the underside of the case or a hidden section before trying it on the exposed surfaces.
