which closed W/C unit is best?
1 Dec 2011
SW3
Dont really have a budget, just theres so many that im struggling to find the best.
I will be cooling an I7 3770K, in a Bitfenix shinobi windowed case, will be doing some overclocking too.
I like the corsair H80 but not sure if it will fit in my case?
Anyone tried?
H80 is not the best, if you can afford to then give a custom made loop a go, Temps are a lot better, The x60 is about the best out of the box.
