Which codces for Vista?
30 Jul 2004
East Sussex, UK
Howzit guys
I'm trying to play some videos within Vista, now I can get them working under XP no prob with rellavent codces. However what codces do I use for Vista, any ideas?
Many thanks all! :D
I've found this codec pack to be useful. IIRC it only includes codecs and no programs you might not want on your system.
If you're running Vista X64 though you'll need to install the 64 bit codecs to get Media Centre playing video files and the 32 bit pack is required for media player.
