Which conroe system
14 Oct 2003
South Derbyshire
system1:
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz Price: £107.99 (£126.89 Including VAT at 17.5%)
Gigabyte GA_965P_DS4 (Socket 775) PCI-Express DDR2 Motherboard Price: £104.99 (£123.36 Including VAT at 17.5%)
GeIL 2GB (2x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit Price: £169.99 (£199.74 Including VAT at 17.5%)
BFG GeForce 7950 GT OC 512MB GDDR3 HDTV/Dual DVI Price: £174.99 (£205.61 Including VAT at 17.5%)
total 655
system2:
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail
Price: £194.99 (£229.11 Including VAT at 17.5%)
Asus P5W DH Deluxe WiFi
Price: £129.99 (£152.74 Including VAT at 17.5%)
BFG 3DFuzion GeForce 7600 GT 256MB GDDR3 TV-Out/DVI
Price: £74.99 (£88.11 Including VAT at 17.5%)
total£668
system3: cut price save my self some money
Gigabyte GA_965P_DS3
Price: £91.99 (£108.09 Including VAT at 17.5%)
OcUK GeForce 7300 GT 256MB GDDR3 HDTV/DVI
Price: £49.99 (£58.74 Including VAT at 17.5%)
total£492
For the first one you will need an additional CPU cooler since it is OEM, is there any particular reason why you are going for Nvidia here? I'd probably suggest an X1800XT with system1 and save yourself some money while not losing that much in the way of performance.
cus the ati cards arnt very good @ old ogl games witch i play a lot
they are noisy and use a lot off wattage
system 1 because:
the gpu is better and as the e6300 has 2mb cache and the e6600 has 4mb cache its worth settling for the e6300 and getting a much better gpu as the 7950 kills the 7600 :) ;)
enjoy
TiZoR said:
what are the chances of getting system 1 to 3ghz
than system2?
Reasonable but it totally depends on the chip itself. Percentage wise the chips from the lower end of the Conroe scale overclock better but you do also have to remember that the extra 2mb L2 cache on the 6600 equates to roughly 400mhz or so.
