- 2 Aug 2006
- Liverpool
which conroe i was thinking of getting the top conroe, is it really worth the price or im i better getting a cheaper one
thanks it is 700wFrankJH said:that looks good a few things
I would choose something around 700w ( you may get away with a 600w with the GX2 )
These guys can.PAULRYAN52 said:can sum1 recommend a good gaming case which can fit watercooling in it
ThanksspinneR~uk said:
from what i've seen... its a case of many of the XS processors are actually getting passed by the 6300s or 6400s.stoofa said:If you can afford it go for the XS.
It's multiplyer is unlocked so you can go for some crazy overclocking with it.
At stock it blasts anything else currently available out of the sky, so overclocked other things don't stand a chance.
The 6700 is a nice enough CPU although I debate if it is worth the extra £150 over the popular 6600.
PAULRYAN52 said:thanks it is 700w
You'll need to remove that link as it's a competitor and against the terms and conditions of this forum. FAQ.PAULRYAN52 said:I looked there but couldnt find info on gamin cases
im lookin for sumfin simlar 2 this
**snip**
