which cooler for i7 920
1 Nov 2003
stevenage
mates getting i7 920 cpu, I have a c2d with a tuniq tower but he says its too big so we cant decide what cooler to get or even whether to stay with standard
which one offers the 'best' cooling, case is an akasa eclipse 62
wont be overclocking (or at least for a while)
he is moving from a c2d using stock cooler
cheers fella's
titan fenrir was one we looked at, not sure how big they are, will take a look at the sharkoon
tbh he has plenty of room as its a decent size case (compared to my soprano)
The eclipse mounts the power supply directly above the cpu socket. If the psu has a 120/135mm fan in the base it relies on drawing air up from around the cpu socket. A tower heatsink blowing front to back and the psu are likely to fight each other for airflow, making this one of the few occasions I'd recommend a Corsair H50. The 920 will hti 4ghz on this relatively easily.
If his psu draws air straight through then ignore the above, and a TRUE/megalahems/titan fenrir will do nicely. Big heatsinks are good btw, and will fit in the eclipse easily.
That's one of the ones which draws air up from the socket then.
This isn't automatically a bad thing, I used a TRUE with a psu much like that one in an eclipse and temperatures were good. I did worry about airflow interference though.
cheers chaps, I think seeing the tuniq in my case put him off but after reading these posts he has relented and is gonna order the tuniq tower extreme
