Which cooler for my E6600?
6 Apr 2007
Portsmouth
I was thinking the Asus Silent Knight - http://overclockers.co.uk/showproduct.php?prodid=HS-012-AS
However seeing pictures of it, it actually looks huge! I've got an MSi 975x motherboard which I think it could possibly fit in. I could take pictures if needed, I was just wondering if anybody could possibly recommend something as good but smaller or just anything you've had a good experience with.
Thanks
Zalman CNPS9700 or Asus Silent Knight?
Which one would you guys personally go for? I see the Zalman has a larger fan, what do you think?
I'd say Scythe Ninja Plus.
:D
Cheers guys.
Sulli if I was going for that does it include a fan? I was thinking of getting the Thermalright 120 but it doesn't include a fan.
Thanks
Edit: Also, I've read some reviews for it and apparently it gets quite loud?
Any of Scythe Ninja, Noctua NH-U12F, Tuniq Tower, Thermalright Ultra-120 (as long as you get a flat one) will do the job very well indeed provided your case has the headroom for them. Check the compatibility charts on the manufacturers' web sites to see if they'll fit your motherboard. The Asus isn't really in the same league as these four.
Scythe Ninja PLUS Rev B, is that correct? Also I'm going to take a few pictures of the inside of my case so you guys might be able to recommend the best for me. I'd like to put either of the Ninja, Tuniq or Thermalright in my machine size permitting but I'm not sure if I can. I'll post back later :).
Thanks
Cheers guys.
Thanks
yes the Tuniq Tower comes with a fan:)
If your not going to overclock then I dont see any point in using anything other then stock hsf, for overclocking id get the best cooler on the market which is the thermalright ultra 120 extreme. Its big but not to big.
Right, back with the pictures. I've been looking at the Tuniq Tower, Scythe Infinity and Thermalright 120. Just for clarification, the Thermalright doesn't include a fan, does it?
Anyway, here are some pictures of the inside of my case (some a little blury, apologies). Ignore the cables flung about, I haven't yet embraced a modular PSU (due next week :D).
What do you reckon I have room for?
http://img252.imageshack.us/img252/1765/img1008cj9.jpg
http://img409.imageshack.us/img409/6233/img1009tg4.jpg
http://img409.imageshack.us/img409/9678/img1010hi7.jpg
http://img252.imageshack.us/img252/9920/img1011ph5.jpg
http://img205.imageshack.us/img205/3888/img1012ze6.jpg
Thanks.
all of them are good and the thermalright doesnt come with a fan - btw google to check compatibility - sometimes capacticors block the big coolers on some motherboards.
