Which cooler
Permabanned
29 May 2009
i'd go with the fenrir given that the fan on the zalman is only a 3 pin jobby, i had a fenrir cooling my amd phenom II 955 rig, done the job very well even at 4Ghz, fitting was very easy too :)
right ok guys , a quick update on this. The fenrir isnt the newer one. Its actually this fenrir http://www.frostytech.com/articleview.cfm?articleID=2383 ... Now this is a much older cooler than my one. Im not sure how much this would cost now with it being discontinued and replaced with the newer model titan fenrir. As for cost. well if its really going to be worth me changing which im not sure about yet, i can get hold of the cooler for £15. What do you guys think. Is it really going to be worth me replacing the coolers???
Just realised i dont think its compatable with socket 1156. damn
