Which cooler?
3 Oct 2013
I'm debating whether I should Install a Corsair H100 or a Thermalright Silverarrow SBE Extreme on my i5 3570k with a mild overclock
Which one should I go for as I have both coolers?
Silver Arrow. Quieter and less change of problems. No potential for problems from pump, hoses, water leaks, etc. Air is simply simpler. :D
And as a bonus the SA SB-E Extreme at same noise level (+1dBA) is 7c cooler.. and 1c warmer at 1/4th the noise (18dBA.. 20dBA sounds four times as loud to us).
Code:
i7 3820 @4.75GHz  Temperature is Delta
Cooler		Delta	RPM	RPM	dBA	Fans
H100		41c	2500		55	2x
SA SB-E		42c	1000	1300	38	TY-150 & TY-141
SA SB-E Extreme	34c	2500		56	2x TY-143
jump in to 3:40 for results
