- 15 Feb 2013
- Edinburgh
Hello all,
I'm planning a new computer build and I'm stuck in a rut trying to decide on which cooling method to use:
Air?
Closed loop water cooled? (cosair h100 etc)
Or custom water loop?
My problem lays with this:
Which method is offers both overclocking levels of cooling while being as quiet as possible?
Now I've done my research and looked at a lot of heat sink fan combos against closed loop water and while they are quiet at normal use it seems the closed loop solution gets reasonably loud during heavy loads and gives around the same cooling (give or take a few degrees).
But in nearly every review/discussion I read it seems to me people say you will get the best cooling and least noise from a custom water loop, is this right?
Should I just accept the cost and go for the full water?
I need help people
(Lets not even go into the aesthetic appeal of water cooling, because I could get lost down that route
Air?
I need help people
