I am currently putting the last (and most important) part to my new build, the question is what Core 2 Duo Chip would you say would give the best bang for buck between these two:
E4400 @£93.99
E6420 @£126.89
I plan to overclock either of the chips to 3ghz or above using the following components, 2gb Crucial Ballistix PC6400, Corsair 520W PSU, Coolermaster Centurion Case, Coolermaster Hyper TX CPU Cooler.
I do quite a bit of divx/xvid conversions using convertxtodvd so would you say double the cache in the E6420 make £33 of difference over the E4400??
E4400 @£93.99
E6420 @£126.89
