- 11 Oct 2005
- Derbyshire
Hi just repaired a computer for someone. Had to get a replacement motherboard but that also came with a cpu in the motherboard
Can you tell which is the better of the 2.
Both socket 775
Intel Celeron(R) D CPU 3.2GHz 3.19GHZ
or
Q6600 socket 775 intel dual core 2 @ 2.4ghz
I have just finished reinstalling Vista onto this desktop with the Celeron installed.
If you tell me the Dual Core is better. Can I just swop it without having to do a re-install of the OS?
Many thanks
Both socket 775
or
Many thanks
