Hi All
I have a little bit of cahs spare and i would love some opinions as to which system would best suit my gaming needs. I play fps like crysis, CoD4 etc and occasionally some WoW. I would like as system that can handle new games coming out in the future.
so its between
AMD build
http://www.overclockers.co.uk/showproduct.php?prodid=FS-046-OE&groupid=43&catid=1184&subcat=
or
Intel build
http://www.overclockers.co.uk/showproduct.php?prodid=FS-154-OK
I currently have windows xp 32 bit, but should i upgrade to vista 64 bit if i go for ddr3?
cheers
james
so its between
AMD build
or
Intel build
cheers
james
) than the previous two you linked to. That essentialy constitutes no saving over the originals you looked at.
