Which CPU Cooler for Silverstone LC10-M HTPC
24 Aug 2013
What is the best low profile cpu cooler that will fit in a Silverstone LC10-M HTPC case, I am limited for space especailly height as a Coolermaster TX3 won't fit and it also hits the metal bar that goes from the from Drive bay to the back of the case (different than the LC10-E case as Silverstone have moved this. I would prefer something that can be push fitted (similar to stock Intel i5 fan) so I don't have to take the motherboard and disconect everything. Something like the Akasa AK-CC7117EP01. I have only got about 10 cm height clearance from the cpu to the top of the metal bar above the cpu. I also have Corsair Vengance pro which I know cause some problems with cpu cooling fans. Any help would be appreciated. :)
