Let me know how you get on with it, as I ordered the 240mm version of it.My Alpenföhn Gletscherwasser 360 High Speed CPU Water Cooler - 360mm arrived today, just need my 5900x and Motherboard to be shipped![]()
Exactly the same setup here (Case, AIO,) though to prolong the life of the AIO I have the tubes at the top as intake.Im using an Artic Freezer Liquid 2 420mm front mounted as intake in my Phanteks P600s, to cool my 5900x. Everything at default, PBO set to 200mhz, idle temps are 27-29c and load temps max ive seen is 60-63c.
According to Gamers Nexus, they stated tubes should be at the bottom so air traps in the top of the rad and does not get passed to the pump i think.
****. Cheers gents guess i better change it around then Lol.Yep exactly this, also the Artic user guide even shows a pic saying tubes at the top is incorrect.
I could have sworn in the Arctic instructions via the QR code bundled with the cooler it said pipes at the top was the right way.![]()
Yeah i can imagine mate, that was the reason i had it how i did.Nah because i double checked this and believe me it was not easy getting those pipes at the bottom, i had to cable tie them to the side of the case otherwise they interfere with the gpu mounting, its a bit of a hassle. I almost bought a new case lmao so i could top mount it.
One question, where are the fan cables for the AIO? When I had them hidden on the other side I couldn’t get the AIO rad screws to line up at the front.Matt i read numerous reports that the tubes should be orientated so they are at the bottom, any air should trap inside the Rad at the top as its the highest point, so your rad is mounted on the front with the tubes at the top?
I changed the fan positions 90 degrees and I was able to hide the fan connectors between fans and now it fits perfectly.One question, where are the fan cables for the AIO? When I had them hidden on the other side I couldn’t get the AIO rad screws to line up at the front.
