I have the same case and because ive an RTX3080 i went with the 280 Freezer as i thought the tubes would not get around the VGA card, but your pic shows i could have done it... oh well... Nice build by the way, very tidy and smart
I see what you mean about the tubes. Can i be bothered to try and tuck them under the GPU though...Fan cables are hidden in the tubing but also they are on the side of the fans, i have mine hidden against the side of the case, it was a bit of work and i had to really push the rad sideways to get the screws to line up but its doable, ive since mounted Phanteks Halos ontop as well, so thats even more cables lol, but it all fits and can be hidden. I basically pulled the side panels off, pulled the top off so i could route the cables as i was putting the rad in place etc. Took a while but its definitely worth doing, the P600S has aload of slider covers as you know which helps with cable routing.
Moving the tubes slightly to rest near the PCI-E cables has removed a bit of the sag, i think.I see what you mean about the tubes. Can i be bothered to try and tuck them under the GPU though...
They've definitely given my GPU a little bit of sag that wasn't there before.
Right, this will be the last time I'll quote myself.Moving the tubes slightly to rest near the PCI-E cables has removed a bit of the sag, i think.
I am not sure if it will work trying to fit the tubes under the GPU. I am not sure how you managed to get yours like that @KentMan
Another Ryuo 240 here (with better cable tidying )
idles around 28-30c, gaming load 50-53c and benchmark max 70c
Ordered an Arctic Freezer 2 420mm AIO for my 5900X, waiting for the cpu to arrive in the next few days, the AIO is a behemoth though so im expecting good things.
@LtMatt you fitted your 420 yet? If so notice much difference over your 360? Im coming from an EVGA Clc 280 on a 3800X, will be interesting to see the difference in Thermal performance
I've got a similar AIO on order. Its not so much the cpu thats the problem its the 30x0 FE it cools the gpu fine but dumps so much heat in the case the CPU is spit roasting in there
Nice. I'm waiting for my dark rock slim to arrive, tomorrow hopefully.Just waiting for my 5950 to arrive later this week and will pair it with a Be Quiet Dark Rock 4.
Im using an Artic Freezer Liquid 2 420mm front mounted as intake in my Phanteks P600s, to cool my 5900x. Everything at default, PBO set to 200mhz, idle temps are 27-29c and load temps max ive seen is 60-63c.
Yeah ive propped it up now, was a bit concerningThat GPU sag is epic!
