Which CPU Cooler??
11 Mar 2007
Hi Guys and Gals,
Im just wondering if anyone can tell me which cooler to buy for my Dore 2 Duo 6400 processor. I currently have the Asus Silent Square on my P4 D but it will fit on my new board, or I was looking at the Arctic Cooler Pro. :confused:
Any help is appreciated
P.S yes I will probably overclock it slightly as well :D :D
Thanks
The arctic cooler pro is the best budget aircooler. It will get you good temps (better than stock anyway) but if you are looking for the best then the Tuniq Tower or Scythe Ninja would be better choices.
100% correct.
I have a tuniq and a 6400.
I get 28/29 in my oven of a room - Good cooler
Sythe ninja for quietness though - Tuniq isn't that noisey... but its not quiet either (comes with fan control)
