I've been looking at cpu coolers for a x4 955be and have come to the conclusion for under £20 these two seem to be the best value.
Cooler Master Hyper 212 Plus: http://www.overclockers.co.uk/showproduct.php?prodid=HS-029-CM
or the
Arctic Cooling Freezer 7 Pro Rev 2: http://www.overclockers.co.uk/showproduct.php?prodid=HS-035-AR
Which of these is better?
For a couple of quid extra I could get the Gelid Tranquillo http://www.overclockers.co.uk/showproduct.php?prodid=HS-001-GD&tool=3
Is it worth it for the little bit extra?
Any advice would be great,
Thanks.
or the
Thanks.
