- 27 Aug 2007
- Whitley Bay
Hi,
Just bought an Asrock Dual-VSTA mobo as need to upgrade my PC from an AMD3200(single core) with 2GB RAM and can't afford new GPU yet.
Couple of questions:
As much as I'd like to go Quad Core can't really push the boat out yet so...
Would I be better chasing an E6300 or E6400 to pop in short term?
Would I get a significant boost over my current setup?
Would I get any overclock with this mobo?
Given I want to run some VMs I assume I should avoid the E4??? series as they don't have the Virtual support?
Is it worth bothering with the E6600 or should I just go Quad if I end up stretching to that amount?
Do I have any other options?
Comments gratefully received
Andy
Andy
