Which CPU fan?
7 Jun 2010
Hello All,
I would like to know what fan people would recommend to get for a Intel® Core™2 Quad Processor Q6600 cpu.
I am after a very quiet one.
Many thanks for your advice.
Andrew
Do you mean a CPU cooler or just a fan to replace the stock fan?
Are you overclocking? Would you like to? Your budget is?
I am after a cooler for the cpu, I am not overclocking, and am mainily using the pc for games, movies and programming.
I have upto 100 pounds available for this, but if you can supply with some choices it would be good.
Thanks,
Andrew
you don't need £100 to spend on a cooler for a 4 year old processor,
Just buy a H50 and an Apache or Viper fan
