which cpu i3 3.9 or i5 2.7
10 Apr 2015
Hungerford, UK, Earth
theres not much in the cost of these, and I'm trying to spec a pc for a mate under 700
i3-6320
i5-6400
which is better for gaming, 2 core i3 higher clock or 4 core i5 lower clock
paired with a 4gb GTX960 playing DAYZ standalone (I believe)
Surely you can do better than either for £700?
Even modern games are not as multi threaded we would like so single/dual core performance is still king, HOWEVER, that may/may not change in the future so place your bets :D
For DayZ.. DEFINITELY single core performance is king.
Windows has to be included that's nearly £100 down the drain.. heres the basket so far, and that's not leaving much for a case, I was hopeing for a decent one but it looks like I may have to go el cheapo
My basket at Overclockers UK:
Total: £657.57
(includes shipping: £11.70)
Does your friend have any other Windows licence for Windows 7 or 8?
The free upgrade program is still active.
Considered purchasing an eligible Windows 7 or 8 licence for much less?
Total: £671.89
(includes shipping: £0.00)
This is the sort of thing I would go for. You may want to add a 92mm exhaust fan also. I would grab a Windows 7 Key online and do the free upgrade - you would still be in budget :).
Edit: I should also point out that the new gpus from both vendors are out soon so it could be worth waiting a month or so on the gpu front.
Total: £657.57
Dropping the 2x H110 and going for non-usb win10 leaves you at ~£555. +85 for z170 and +40 to bump the i5 up to 6600k leaves you at ~£680.
