Which CPU is better......
2 Jan 2004
Chesterfield
Can anyone tell me which is the better processor (for a laptop) between the Intel Celeron T3500 or the Intel Celeron 900?
Thanks....
StevieP
The Celeron T3500 is dual core and therefore will be much better.
Running anything these days with a single core processor is not that great. Which is what I am finding with the single core atom in my netbook.
I looked at netbooks but decided it wouldnt be ideal for my work. I ended up getting a 13" laptop with a celeron dual core clocked at a measly 1.2ghz (its a ulv). Even though its clocked quite a bit lower than the atoms its still fairly nippy and performs better because its dual core.
Definitely go with dual core if you can :)
