Which CPU temp for fan curve in the bios?
26 Feb 2004
Hampshire, England.
Hi guys,
I'm trying to get my head around which temp overall, the bios uses when I'm setting up a curve?
At the moment my fan speeds are all over the place! In the bios, I see only one reading for the cpu temp but with my apps in Windows I see multiples, as pictured above. Which one is it that the curve I see takes the reading from?
Thanks.
The bios will use the only CPU temp it sees.
I think you're more asking which temp in HWMonitor is the one the bios is using which will probably be CPUTIN.
Nice one, will try when I get home. To be honest though, at the moment temps aren't an issue - 5700x under an AIO, with newly applied MX-6 :)
