Which CPU temp monitor should I believe???
21 Aug 2006
OK, so there is 10ºC difference between these which should i believe? Getting close to 70ºC (M0 e2160, so limit is 73ºC). I'm currently at 3Ghz at 1.4v and want to get minimum 3.2Ghz out of it so need to know which temp is accurate :confused:
TIA
i am more inclined to believe realtemp as it is 30º at boot-up (same as bios), coretemp shows 20ºC idle under a Tuniq - seems unlikely to me, but thx for the comments
