nexxos XP,
Swiftech Apogee,
XSPC block,
(all on half inch)
i ask because i have orderd the nexxos from fleebay but the guy claims its gone missing in the post...
"This item was mailed out from here last week, the same day you bought it.
You should have it by now.
Royal Mail have probably lost it.
Normally if RM loose a package, i just send out another one. But, you got
the last NexXxos block i had in stock. I've got a few more on the way from
Alphacool, but these are going to take a few days to get here.
I'm really sorry about this. You can either hang on a few days, and see if
either your missing block arrives, or if more arrive from Alphacool so I
can forward you another one. Alternatively i can give you a refund, or
switch your order to a Swiftech Apogee or XSPC block." - blokey from fleebay.
so i need to know which block is better.
thanks
Swiftech Apogee,
XSPC block,
(all on half inch)
thanks
more opinions still required too
im not even sure what one is
