in need of a few pointers, first ever watercooling attempt coming up, going to be going with the XSPC 750 dual bay res/pump, EK coolstream 360 rad, mayhems coolant and compression fittings (probs EK or XSPC again @ 3/8") so that just leaves the CPU waterblock. Going to be running a 2011 rig (3820 i7 on UD3 mobo) and only running a single loop on the CPU only, and im on a budget of 50-70 quid for the waterblock, which leaves me with 2 options i think, which are the Swiftech Apogee GTZ (59.99) and the XSPC raystorm (49.99) and was wondering which you would recommend? If there aint much between them, then ill probs go for the XSPC due to the LED inclusion (going green and black stealth rig, so the led lights would complement perfectly, but i dont mind the look of the swiftech block either)
also, if anyone can recommend a good rad for under 60 quid thats better than the EK one, feel free to leave a comment too
