After having researched processors for a while, it seems that the x4 955 and i5 750 seem to be the best for those on a budget.
Which of the two would you recommend for gaming? I would definitely overclock the chips so considering this, what would be the best one to buy? If I was to buy the 955 I would buy it new seeing as their going for around £100 but if I was to buy the 750 I would buy it second hand.
Are processors risky to buy second hand even if they have been overclocked?
I was also looking at the i5 760. Is there any noticeable differences in performance or overclocking between the 750 and 760?
I will also need a motherboard so could anyone recommend me a 1156 motherboard? Again I would consider buying this second hand but I heard that motherboards are a component that you shouldn't buy second hand.
Is this true or are they fine to buy second hand? The prices for 1156 would probably be cheap seeing as everyone is upgrading to sb.
Any advice would be great,
Thanks.
Thanks.
