Which cpu..
Caporegime
25 Jul 2003
FR+UK
Just after some advice from those who are more upto date with processors then myself, as I haven't bought hardware in quite a while.
I'm not really sure which is the best route to go; AMD or Intel, i5 or i7. I basically want to build a new PC that will be used for the range of things: rendering, graphic design, gaming (not so much top end, but Diablo III will require a hefty pc), and folding.
There are so many different processor types now it will take a while to read around them, which I will do. But I was just hoping someone knowledgeable could give me advice.
Buget plz, but if you can go for i7 920 it's just the job for you especially with you rendering, graphic's design, etc. :)
If you wont be overlocking and want the most power for your pound then the new i5/750 is the CPU to get.
The accompanying P55 boards are relatively cheap too especially when compared to an X58/920 setup.
If you want a little more power than the 750 then splash out on the i7/860. Avoid the 870; a pointless waste of money.
People will advocate the 920 in here because it's a stonking overclocker for 200 quid. But it does need to be overclocked.
At stock it's not that great when stood next to the newer Intel chips.
Thanks yashiro - to confirm that I won't be overclocking.
@oggiet - I don't know much about the HT on the icores - I understand it effectively doubles the cores (like HT on the old P IVs?), but just how useful is that at present?
The Intel Core i5 750 2.66Ghz (Lynnfield) (Socket LGA1156) - Retail at £159.99 looks like a good building block to build a system around to me. So my next question would be to ask for motherboard recommendations :p.
And I suppose the advantage of that i5 is I could always upgrade to an i7 860/920 at a later date (I presume I can as they share the 1156 socket)?
Hmm, Tri-channel memory kits only work with the i7, or with socket 1366?
