which cpu?
The haswell is a different socket I believe, so no.
The i5 is probably the best choice for gaming. I have the 3770k, my friend has the 3570k, no difference whatsoever. His computer keeps up with mine perfectly well, even in benchmarks.
With gaming, as long as the CPU isn't a bottleneck, the graphics card will make the biggest difference by far.
It'll make a difference in processor intensive applications like encoding, rendering etc. but not for games :).
The 3570k is the obvious choice if your main use is gaming. The hyper threading of the i7's is basically useless in that case
