Hi have at the moment got single card and thinking of getting a second to maximise the mobo and gaming pleasure
It's got a Ati His 6970 at present, would the second slot be able to take full advantage of another 6970 or should i consider a different cheaper card.
I'm Thinking that with the mobo that I have doesn't do full x16 on both slots and says will comforms them to both x8. how will this effect it. What will the Gen 3 pcie will have any effect also.
THanks for thoughts.
It's got a Ati His 6970 at present, would the second slot be able to take full advantage of another 6970 or should i consider a different cheaper card.I'm Thinking that with the mobo that I have doesn't do full x16 on both slots and says will comforms them to both x8. how will this effect it. What will the Gen 3 pcie will have any effect also.
