that would be PC2-3200wesley said:ok, tell me if i'm wrong
E4300 = 9 x 200mhz = 1800mhz (DDR2 400/PC3200 RAM needed)
tommy_knockers said:Hello. Will a E4300 be severly handicapped by 2x1gb DDR2 dual channel 4-4-4-12 (can get 3-3-3-9) Samsung 4300 (533mhz) ram?
Will it limit me.
Will be wanting to overclock it a fair bit (around 3ghz). Have a zalman 9700 to cool it.
The motherboard has a **** bios. I cannot change voltages but only set it to high or normal voltage. I can only increase the frequency of it as well as few other things.
cheers
