Which DisplayPort Switch?
29 Aug 2010
Cornwall
Hi,
I've got a three PCs that I'm trying to connect to 2 monitors, a 1440p 144hz Freesync screen and a 4K 60hz screen.
The only ports I can use on each to get the full resolution at the full speed is a DisplayPort and an HDMI 2.0 port (both have the same ports).
Obviously this doesn't go so what I really need is a DisplayPort Switch. well either 2 of them or one of them and an HDMI 2.0 switch. Can't do 2 HDMI 2.0 switches because GPU vendors seem to have decided that 3 DP and 1 HDMI is the config to go for.
So can anyone recommend a DisplayPort Switch that can do 1440p/144 and 4k/60?
I'm struggling to find many options other than a LINDY one, which I've tried 2 of with mediocre results.
What about an HDMI 2.0 switch for the same job?
I believe there are a lot more of these available (probably because TVs use HDMI 2.0), but finding a good one...
Are there any other options I'm missing?
Thanks.
