From the available E2xxx CPUs which are more likely to run 3 GHz at stock volts? (and thus cooler?) Does the multi make any difference (allowing you to run a lower FSB in this respect to vcore?)
Or is it just based on chance? Do they have differnet starting vcores?
My new rig is geared for silence. Heatsink will be a XP-120 (have it from my old rig) or a TRUE. Motherboard P35. RAM DDR2-6400.
When it's all stable I'm planning on using Speedstep (for watching films/web browsing etc.). Does speedstep adjust itself (e.g. if you are OC to 3 GHz and it would drop to say 1.2 GHz (guess)) or is it fixed (i.e. it would always drop to 1.2 GHz no matter what your overclocked to?)
I've never owned an Intel system btw hence the noobness.
