- 16 Dec 2014
For a 3 way GTX 970 Setup? 3 cards are together with 2 slot spacing. Which terminals do i need?
any of these should be fine, I'd invest in some silicone sealant too though as when i fitted mine, it was a pain to get the seals in.
YOUR BASKET
1 x EK Water Blocks EK-FC Terminal TRIPLE Serial - Plexi £31.19
1 x EK Water Blocks EK-FC Terminal TRIPLE Parallel - Plexi £31.19
1 x EK Water Blocks EK-FC Terminal TRIPLE Parallel £17.99
1 x EK Water Blocks EK-FC Terminal TRIPLE Serial £17.99
Total : £107.95 (includes shipping : £8.00).
Just to be sure, can you tell me what motherboard you're using?
Next question. Better cooling? Serial or Parallel?
Luc,
X99 SOC Force
OK and which CPU?
5820K
Fantastic! I can then confirm you that the triple terminal is the one you need in any flavor (serial or parallel) you like![]()
Luc,
Do I need to order any special fittings for it?
